When I use the node editor, in cycles render view, the object isn't affected in 3Dview, even if I turn into rendered mode….
Forum Archive When I use the node editor, in cycles render view, the object isn't affected in 3Dview, even if I turn into rendered mode….
  • #4325
    coolgamer
      When I use the node editor, in cycles render view, the object isn’t affected in 3Dview, even if I turn into rendered mode.
      It’s displaying only on preview window in material region but not in 3D VIEW. Did I miss something?
      #22347
        Is your 3D viewport paused?
        #22348
        coolgamer
          I find the solution, thanks, when i create a new material, i forgot to delete the oldest so I could’nt displaying the results on 3DVIEW.
        • The topic ‘When I use the node editor, in cycles render view, the object isn't affected in 3Dview, even if I turn into rendered mode….’ is closed to new replies.
