When I try to select my seem on the monkey the Shift G select by seem works but when I try to select mirror I get a messag…
Forum Archive When I try to select my seem on the monkey the Shift G select by seem works but when I try to select mirror I get a messag…
  • #4260
    Tony Vasile
      When I try to select my seem on the monkey the Shift G select by seem works but when I try to select mirror I get a message “0 edges mirrored, 30 failed. Any ideas what I am doing wrong?
      #22227
        That error means your mesh isn’t 100% symmetrical. The tool only works with perfect symmetry.
        #22228
        Greg Vaughan
          I am getting the exact same issue… foloowing the tutorial and using the monkey… can you suggest why the model isn’t symmetrical? or perhaps what that means because that answer doesn’t help me to achieve the result at all as it stands.
        • The topic ‘When I try to select my seem on the monkey the Shift G select by seem works but when I try to select mirror I get a messag…’ is closed to new replies.
