When I try to run the OSL color script I get an 'Invalid Syntax' error. I've copied and pasted directly and double checke…
Forum Archive When I try to run the OSL color script I get an 'Invalid Syntax' error. I've copied and pasted directly and double checke…
  • #6052
    lordgert
      When I try to run the OSL color script I get an ‘Invalid Syntax’ error. I’ve copied and pasted directly and double checked – any ideas what’s wrong?
      #24843
      Jonathan Lampel
        You don’t need to click on Run in order for the OSL script to work, instead just load it through the node editor. It’s throwing a syntax error because the text editor is expecting a Python script, and hitting Run Script will try to execute it using Python.
      • The topic ‘When I try to run the OSL color script I get an 'Invalid Syntax' error. I've copied and pasted directly and double checke…’ is closed to new replies.
