Forum Archive › When I switched the view to solid, the shape still did not show up. Weird . . .
What I meant by that is, when I was supposed to change the view to solid, the outline of the model did not show through the texture.
0:59 of the video.
Hmmm . . . this is interesting. It won’t do it in Cycles Render, but it will do it in Blender Render.
After switching to texture paint while in cycles render, in the 3D viewport, press N and deselect shadeless. This fixed that issue for me. Hope this helps.
Cool, thanks!
Thank you good sirs. :{)
It only works for me under Blender render. Only “Shadeless” will switch between the two in “Cycles Render”.
All the best,
Ido
