When I switch to texture paint mode, my object turns pink and I get a 'missing data' error and a 'missing texture slot' er…
Forum Archive When I switch to texture paint mode, my object turns pink and I get a 'missing data' error and a 'missing texture slot' er…
  • #4433
    Noah Ingerling
      When I switch to texture paint mode, my object turns pink and I get a ‘missing data’ error and a ‘missing texture slot’ error at the top left. What step am I missing?
      #22523
        That’s normal behavior. Did you watch this lesson? https://cgcookie.com/lesson/creating-an-image-texture/
        #22524
        dem1
          same problem . i can’t understand
          #22525
          dem1
            Ok great , SOLVED !
            #22526
            leadfaith
              @dem1 What did you do to solve it? I still have a pink object. I rewatched that lesson several times, I have a texture but it’s asking for a material and paint slot. It’s colored when I have the 3D viewport in edit mode and pink in texture paint mode.
              #22527
              leadfaith
                After messing around with it, I discovered that my problem was the painting mode located in the toolbar of the 3D viewport under the “slots” tab. I switched my Painting mode from the default of “material” to the “image” Painting mode using the dropdown box, and selected my “Texture” texture from the Canvas Image dropdown box. It worked fine for me after that!
                #22528
                Noah Ingerling
                  Thank you so much leadfaith for that solution! I had gone back through the lessons and I still couldn’t make it work. Now i am good to go. 🙂
                  #22529
                  Johnathyn
                    leadfaith’s solution worked for me as well. Thanks!
                    #22530
                    enzeart
                      +1 internets to my boy leadfaith for the clutch answer
                    • The topic ‘When I switch to texture paint mode, my object turns pink and I get a 'missing data' error and a 'missing texture slot' er…’ is closed to new replies.
