Forum Archive › When I selected cube to try unwrapping with follow active face I obtain No active face error
solved
What did you have to do to solve it?
Had the same problem. Changed from “vertex select” the “face select” and selected all. Then I code an active face (dotted).
I had all cube’s faces selected I had to deselected one face and reselect it. Ps. Sorry the late answer
Ran into the same problem. Your tip worked. Thanks.
