When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT???
Forum Archive›When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT???
Looks like it did indeed separate by selection, so I’m guessing somehow the bounding box display is turned on? You can turn it off in the object properties under display.
Author
The topic ‘When i select the inner circle of the vault im suppose to click (P) then separate selection instead of doing what its suppose to it makes this red box. WHAT DO I DO TO FIX THAT???’ is closed to new replies.
