when I select object offset, it completely distorts the staircase into exponentially larger and different shapes… i just…
Forum Archive when I select object offset, it completely distorts the staircase into exponentially larger and different shapes… i just…
  • #5481
    nickolinasf
      when I select object offset, it completely distorts the staircase into exponentially larger and different shapes… i just want to replicate the video, but the object offset isn’t working for me 🙁 🙁
      #23939
      gkw0
        Me too. I’m just about to try everything from the start and see if it works, but even so, I would very much like to know what went wrong.
        #23940
        gkw0
          I tried the whole thing again from the beginning and didn’t have the problem the second time through.
          #23941
          Randy Haims
            I am having the same problem and tried starting over multiple times. Does anyone know why this may be happening other than just to start over? Thanks!
            #23942
            Randy Haims
              Figured this out. You have to make sure the rotation and scale are zeroed out and the scale 1, 1, 1 – was at the end of the video. Also make sure to scale in edit mode this seemed to work for me.
            • The topic ‘when I select object offset, it completely distorts the staircase into exponentially larger and different shapes… i just…’ is closed to new replies.
