When I press “Only Render” like in 4:06 – Only the ShaderGizmo appear. The room i s completely hidden.
Forum Archive When I press “Only Render” like in 4:06 – Only the ShaderGizmo appear. The room i s completely hidden.
  • #6846
    Ido Reshef
      Hi,
      In  4:06, Kent is ticking a “Only Render” tick box in the display properties panel – and we get a clear view for the newly baked Gizmo and room. From some reason, only the gizmo appear for me after ticking.. all the baking was done correctly by the way. Any notion why that occurs ? using 2.78.
      Thanks and all the best,
      Ido
      #26071
        Would you mind sharing a link to your .blend file? Sounds like I need to take a closer look at the settings to figure out what’s wrong.
      • The topic ‘When I press “Only Render” like in 4:06 – Only the ShaderGizmo appear. The room i s completely hidden.’ is closed to new replies.
