When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it
Forum Archive›When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it
so when the inputs overlap the first input just gets disconnected and i have to plug it into the bottom spot, in the video the overlapped shadder jumps down a slot on the mix shader. is there a setting i have to enable?
Yeah by default it’s better if it swaps like before, the move was if you wanted a disconnect then you hold ALT. That behavior should be in reverse.
Author
The topic ‘When i plug a shader in mix over another shader allready plugged it it does not move it down to the next input of the mix shader like the video does it just disconnects it’ is closed to new replies.
