When I hit the inset hotkey, it doesn’t remember my previous settings, why is that?
Forum Archive When I hit the inset hotkey, it doesn’t remember my previous settings, why is that?
  • #7116
    Louis Middleton
      Jonathan Lampel
        Hmm, I’m not sure why it wouldn’t. If need be you could also use Shift+R to exactly repeat your last action.
        #26535
        Nicholas Yang
          It doesn’t remember last settings for me either (2.79b). Shift+R works fine, but not when following this video because there are other operations in between the two insets. F3 (Recent History) is an alternative to repeat an operation with settings, but if you repeat operations, it might be hard to distinguish which is which.
          #26536
          Jonathan Lampel
            Hey @nyanginator , since then I found that Blender only remembers the settings if you input the numbers manually after confirming the operation with the mouse. Hope that helps!
          • The topic ‘When I hit the inset hotkey, it doesn’t remember my previous settings, why is that?’ is closed to new replies.
