WHEN DOING FINE DETAIL ON FACES (NOSE ETC), THE RESULT IS BLOCKY – EVEN WHEN USING DINAMIC TOPOLOGY, NOTHING SEEMS TO SUBD…
Forum Archive WHEN DOING FINE DETAIL ON FACES (NOSE ETC), THE RESULT IS BLOCKY – EVEN WHEN USING DINAMIC TOPOLOGY, NOTHING SEEMS TO SUBD…
  • #5376
    MARY THORNTON
      WHEN DOING FINE DETAIL ON FACES (NOSE ETC), THE RESULT IS BLOCKY – EVEN WHEN USING DINAMIC TOPOLOGY, NOTHING SEEMS TO SUBDIVIDE,AND SMOOTHING DOES NOT HELP. AM I DOING SOMETHING WRONG?
      #23764
        Which brush are you using? The Grab brush doesn’t modify topology, nor does the Smooth brush. All other brushes should modify the topology though.
      • The topic ‘WHEN DOING FINE DETAIL ON FACES (NOSE ETC), THE RESULT IS BLOCKY – EVEN WHEN USING DINAMIC TOPOLOGY, NOTHING SEEMS TO SUBD…’ is closed to new replies.
