What will the main_edit.blend be used for? Is it the blend file that will act as a Video Sequence Editor and point to the …
Forum Archive What will the main_edit.blend be used for? Is it the blend file that will act as a Video Sequence Editor and point to the …
  • #6045
    gamejob
      What will the main_edit.blend be used for? Is it the blend file that will act as a Video Sequence Editor and point to the comp.blend, where the comp.blend combines the layout.blend and anim.blend?
      #24824
      Wayne Dixon
        Yep it’s the main VSE file.
        #24825
        Wayne Dixon
          It should just link in all the most recent rendered outputs. That means it will probably start with the layout or animatic files and eventually be replaced by the openGL renders of the animation, and then finally the actual rendered images.
          So it will basically be the file that you render out to be your final full movie.
          #24826
          gamejob
            Okay I think I got. Thanks for the answer!
          • The topic ‘What will the main_edit.blend be used for? Is it the blend file that will act as a Video Sequence Editor and point to the …’ is closed to new replies.
