What is ‘Object Velocity’ doing if ‘Normal Velocity’ is handling the speed and direction of emission?
Forum Archive What is ‘Object Velocity’ doing if ‘Normal Velocity’ is handling the speed and direction of emission?
  • #8776
    bishop3101
      Grant Wilk
        The two velocities add on top of each other.
        You can imagine the normal velocity as the base-velocity. The particles will ALWAYS be emitted at -1 m/s relative to the normal of our emitter.
        The object velocity is a velocity that’s added on top of our base-velocity. As the rocket (and inherently, the emitter) gains velocity, the particles will be emitted at -1 * n m/s, where n is our objects velocity.
        So our sum velocity is:
        velocity = normal_velocity +  object_velocity
        (-(1 + n ) m/s) = (-1 m/s) + (-1 * n m/s), where is the velocity of our rocket
        #29342
        Jahim Clarence
          I appreciate this explanation. Even though it wasn’t something I was stuck on,it was very informative.
        • The topic ‘What is ‘Object Velocity’ doing if ‘Normal Velocity’ is handling the speed and direction of emission?’ is closed to new replies.
