What can I do if there is white noise in the render?
Forum Archive What can I do if there is white noise in the render?
  • #12064
    Jonathan Nunez
      I noticed that my render has some small white dots on the wheels part…I didn’t see this addressed thru the lesson, so I wondered what could be done?
      #57257
      Shawn Blanch
        Those are call fireflies.
        There is a cool addition to cycles render where you can add a denoiser to the compositer (it’s working in blender 2.82a I know for sure). You just enable the “use nodes” one the compositer workspace and then add a DeNoise node after the render and then connect that to the output. It will remove your fireflies if you just want a quick and dirty.
        The new lighting course by@jlampel is probably worth looking into as well.
      • The topic ‘What can I do if there is white noise in the render?’ is closed to new replies.
