What am I doing wrong? When I delete the first Divide node, the result is different, although I have the rest of the nodes…
Forum Archive What am I doing wrong? When I delete the first Divide node, the result is different, although I have the rest of the nodes…
  • #4571
    Pather Thomas
      What am I doing wrong? When I delete the first Divide node, the result is different, although I have the rest of the nodes exactly the same. The only solution is to change the value in the Divide node before Modulo to 0.1. Then it gives proper result. Or I can crank up the value to 10x before and it works as well. But as for number of cuts, moving the decimal point seems like an error. Everything works just fine untile I delete the first Divide node, the one right behing Mapping node. The object has scale and rotation applied. Thank you.
      Screenshot of my node setup and the 3D view pane.
      http://i.imgur.com/9KDlOOO.png
      #22789
      Pather Thomas
        Yeah I think I got it. My object was way to small and since we are using object coordinates, it depends on the dimensions of the object. So nevermind 🙂
      • The topic ‘What am I doing wrong? When I delete the first Divide node, the result is different, although I have the rest of the nodes…’ is closed to new replies.
