What about NormalMap?
Forum Archive What about NormalMap?
  • #6599
    raulbarbos
      hey man, I was wondering, is that possible, using this method, to export the normalmap?
      #25628
        Yes, you can convert the greyscale bump I generated into a normal map.
        #25629
        Chuck Shultz
          Once converted into mesh, the hair is not appear to be subject to wind forces. What would you recommend if you want the final product to show hair movement/bounce with head movement or wind effect?
          Thanks
          #25630
          Chuck Shultz
            Once converted into mesh, the hair is not appear to be subject to wind forces. What would you recommend if you want the final product to show hair movement/bounce with head movement or wind effect? ( am asking hair stands and the end of the shoulders, etc)
            Thanks
            #25631
            Sara (Starry)
              Hi Chuck,
              Maybe you could try adding a cloth modifier to your finished hair cards?  That should interact with wind and if you fiddle with the cloth settings you should get something pretty good…
              #25632
              Chuck Shultz
                ty
              • The topic ‘What about NormalMap?’ is closed to new replies.
