Weird shading on the faces while smooth mode is enabled
Forum Archive Weird shading on the faces while smooth mode is enabled
  • #16994
    Amine Ben Rejeb
      I don’t know what’s going on.. i tried to line up all the vertices (S, Z, 0) time and time again with no difference whatsover.
      Same goes for the back of the model
      Link to blender file: https://we.tl/t-cPg3KxVGnO
      #81784
      Amine Ben Rejeb
        I fixed it! i don’t know if it’s a good solution long term but i just applied mark sharp on the edges that were causing problems
        #81785
          That is a smooth result for sure, looks so pretty. You just have to enable harden normals in your bevel modifier under the shading options and it’s all good.
        • The topic ‘Weird shading on the faces while smooth mode is enabled’ is closed to new replies.
