Weird shading issues
Forum Archive Weird shading issues
  • #19600
    Ondřej Madeja
      Hey
      I’ve been trying to model the cube in a same way as shown in the course, but I have been running into these weird shading issues while trying to create more dimples. Here is the image
      #92826
      Dwayne Savage
        I think you’ve got your dimples(Cutter objects) to close together. It looks like they are overlapping and causing the weird triangulation.
        #92827
          Hi Ondřej  @Paker ,
          Is your Cube set to Shade Smooth, maybe? (Doesn’t look like it, but…?) Shade Smooth By Angle would then be a better option.
          There’s actually quite a lot that can go wrong with Booleans, but this doesn’t look like a major thing. But I can’t reproduce the result, so maybe you can post a link to your .blend file (via Dropbox, GoogleDrive, or so). That is if Dwayne didn’t already solve the problem, of course.
          #92828
            Yeah, post a link to your file so we can take a close look at it. Put our Sherlock hats on.
            #92829
            Ondřej Madeja
              Okay, so I have tried to put them further apart and that had created another shading issue :D. Also, when I try to join the dimples, the cube and the dimples move into a weird wireframe form when the boolean is used. I have weird boolean issues in this course overall :D. You can get the file here
              #92830
                Hi Ondřej,
                The issue is, that the intersections of the dimples are not a straight line (the middle is not flush with the Cube, if that makes sense):
                This image is after Applying the Boolean Modifiers.
                So basically, the size of the dimples is too large, as Dwayne suggested.
                #92831
                Ondřej Madeja
                  Hey!
                  I made the size much smaller so that it doesn’t touch at all. But now there are weird outer rings around the dimples and also weird shading issues that I hope are visible from the image. I thought this won’t make much issues when I apply some texture to it, but sadly it is quite visible. I also applied all the transforms, but that didn’t do anything. Here is the image
                  Thanks for your help, guys!
                  #92832
                    Hi @Paker ,
                    That’s this angle:
                    You might need to play with your Smooth By Angle Settings…
                  • The topic ‘Weird shading issues’ is closed to new replies.
