Hi Natalia,
If you enable X-ray, you can select through the invisible walls (and Edit stuff).
In Eevee, you can set Backface Culling in the Material Settings:
In Cycles you can hack the Material like this:
No need to understand this yet, but basically, when the Normals of a Face are turned away from the Camera, they use the Transparent Shader.
