Voxelize Python Script problems
Forum Archive Voxelize Python Script problems
  • #11229
    jesse94
      I’m having problems with cg cookie’s video on creating a voxelize script I made sure to copy the object but after the 9th line of scripting I pressed run script and in the info it said  python script failed, check the system console witch I did but I still don’t see the problem please help heres my blend file by the way I’m using blender 2.81 http://pasteall.org/blend/index.php?id=52794
      Creating ay
      #52773
        Hi jesse, you misspelled sourceName (as sourseName) in line 4.
        And sourseName is not declared, that’s why the script fails.
        #52774
        jesse94
          I’m still having troubles with cg cookie’s video on creating a voxelize script this time I’m stuck on the part after bpy.context.area.ui_type = ‘UV’ when I go to the uv editor and select the mesh the UV’s wont project on the text heres my blind file http://pasteall.org/blend/index.php?id=52797
          #52775
            Your mesh doesn’t have UV’s. Unwrap it and the UV’s will show up. Your script seems to be ok so far.
          • The topic ‘Voxelize Python Script problems’ is closed to new replies.
