Viewport very slow can’t work with nodes
Forum Archive Viewport very slow can’t work with nodes
  • #16372
    Leszek Copa
      Hi
      I’m trying to do Fundamentals of materials and shading but the workflow becomes so slow that I’m barly able to use the nodes. I did reset to factory settings nothing helped. I’ve also tried different version 3.4 and 3.5.1 same problem. I have reduced undo steps to 32 didn’t help. Render set to cycles Viewport 16 steps. No denoise selected. In my understanding it should work smooth without any problems.
      I also sure that my PC is strong enough to handle single object ligthing.
      – 1th Gen Intel(R) Core(TM) i5-11400F @ 2.60GHz 2.59 GHz
      – 32 GB
      – GeForce RTX 3060 (drivers upto date)
      Any ideas?
      Thanks
      #79221
      Leszek Copa
        It’s me again problem sloved but I will leave thread for someone else as I havn’t seen this here.
        Not sure what happend but I have tured on denoise in viewport sampling and changed from automatic to OptiX. Now it is soooo smooooth 🙂
        #79222
          Computers being computers. The Matrix or Terminator will never happen and if it does, some glitch will make the machines go all crazy and reboot with a blue screen.
        • The topic ‘Viewport very slow can’t work with nodes’ is closed to new replies.
