Video 1 time 7:14
Forum Archive Video 1 time 7:14
  • #17493
    The curve option does not exist in the latest blender. what am i supposed to do now? ;-;
    #84089
    Dwayne Savage
      Make sure you are in object mode.
      #84090
        Yes, you need to be in Object Mode. Also, you get less options by default in the Curve menu:
        You need to enable the Add Curve: Extra Objects Addon to get the extended list.
        #84091
          Everything he does in that time frame is still available in the latest Blender as is, as the others have suggested, maybe you were in edit mode and you didn’t see the options. And also remember that if you get stuck because of versions differences, it’s a much better to use the version of Blender that is being used in the video.
          #84092
          Thank you, it helped. I accidentally put the SurfCurve instead of the NurbsCurve
        • The topic ‘Video 1 time 7:14’ is closed to new replies.
