Vertices are making a shade when adding node to grey plastic
Forum Archive Vertices are making a shade when adding node to grey plastic
  • #21083
    Erik Vos
      Hi, when I add this node with a slight bevel to “grey plastic” all of a sudden I get this shade to the grey arrows-selection-thing? I can’t dissolve any of those edges, they are not marked sharp, the vertices are all in the same plane, I can’t change the bevel in the modifier because it would effect the whole console… what to do?
      #98315
      Erik Vos
        Dont know why the image wasn’t showing in the first place:
        #98316
          HI Erik,
          Make sure your Normals are all correct (enable Face Orientation in the Overlays Dropdown).
          Also, for clarity, you are talking about the Bevel Node in the Shader, right?
          #98317
          Erik Vos
            Thanks! That was the problem! And yes, I was talking about the Bevel Node in the Shader
          • The topic ‘Vertices are making a shade when adding node to grey plastic’ is closed to new replies.
