Vertex Bevel affecting Edge bevel
Forum Archive Vertex Bevel affecting Edge bevel
  • #21592
    Joe Morgan
      Hey,
      When I move my vertex bevel modifier above the edge bevel one, the bevels of the 4 out edges shrink. Even tho the bevel weight of the edges and vertex affected are set to 0.
      Image Link
      Blend file
      Thanks for the support
      #100379
        Hi @Stoic ,
        From the image, I’d say it’s the Clamp Overlap kicking in.
        Now let me look at the file…
        #100380
          Yes,
          It’s the Clamping, but you can’t just disable it. What you can do, is make the (Amount of the) Vertex Bevel smaller:
          That way this (Active, white) Vertex from the Vertex Bevel, doesn’t prevent the Vertex from the Edge Bevel from ‘going’ up further:
          #100381
            In case you are wondering, there are multiple ways of going about it, but since it’s a beginner tutorial, JL goes the easiest route. So don’t worry if you feel is a bit convoluted in the beginning, you’ll get used to modeling bit by bit.
            #100382
            Joe Morgan
              Thanks Martin and Omar, problem solved.
            • The topic ‘Vertex Bevel affecting Edge bevel’ is closed to new replies.
