Using the shader VOLUME ABSORPTION on the VOLUME wouldn´t be the same as using the volume absorption you made on the Mappl…
Forum Archive Using the shader VOLUME ABSORPTION on the VOLUME wouldn´t be the same as using the volume absorption you made on the Mappl…
  • #4558
    Using the shader VOLUME ABSORPTION on the VOLUME wouldn´t be the same as using the volume absorption you made on the Mapple Syrup?
    #22773
      It’s the same conceptually, but very different in utility. The Volume Absorption and Volume shaders are more physically accurate, but I like the “fake” one because it’s more flexible and tweak-able.
    • The topic ‘Using the shader VOLUME ABSORPTION on the VOLUME wouldn´t be the same as using the volume absorption you made on the Mappl…’ is closed to new replies.
