Using knife tool to cut a 45 degree angle is a bit involved. I recommend the Shear tool with a value of 1 or negative 1 depending on the orientation, this does a 45-degree transform in one step.
Thanks for the tip, chromemonkey! I’d love to cut that process down to 1 step.
Author
The topic ‘Using knife tool to cut a 45 degree angle is a bit involved. I recommend the Shear tool with a value of 1 or negative 1 d…’ is closed to new replies.
