Use (manual) UV unwrap and UV smart project at the same time?
Forum Archive Use (manual) UV unwrap and UV smart project at the same time?
  • #10555
    tobles
      Heyo,
      I was wondering if I can use both methods for UV unwrap at the same time. I have a model consisting of multiple objects and I’d like to unwrap all of them with cutting seams except for one. For this one I’d like to use smart unwrap but have everything on them same UV layout image in the right scale. Is this possible? Somebody knows how?
      Cheers,
      tobles
      #50231
      jamesley
        Hi simply select the object in edit mode and use smart unwrap. After having unwrap all your object selects them in “UV editing” and in the “UV” menu selects “average island scale” and “island packs””
        #50232
        Markus Berg
          In edit mode, select only the faces/objects that you’d like to use manual unwrap. Then after that has been unwrapped, select the rest of the faces/objects and perform the smart uv project. And then you can just do what jamesley said, “Average islands scale”, and “Pack islands”.
          #50233
          tobles
            Awesome! That worked out just fine. Thanks to both of you.
          • The topic ‘Use (manual) UV unwrap and UV smart project at the same time?’ is closed to new replies.
