Unexpected Bevel Geometry on Side Panel
Forum Archive Unexpected Bevel Geometry on Side Panel
  • #15365
    Riley Linch
      This issue only occurred once I added the last panel into place. Not sure what went wrong here.
      #75137
      Riley Linch
        #75138
        Riley Linch
          Okay it went away as soon as I moved the vertex down a hair, even though it was already alined properly with the other vertices. Any suggestions on why this happened would be appreciated!
          #75139
            Hi Riley,
            the screenshot isn’t helping me at all, in this case. If you haven’t completely destroyed the problem by fixing it, yet, maybe show the model in Edit Mode and tell us where the problem area is…My guess is, that that Vertext you moved wasn’t as well aligned as you thought…
            A link to your .blend file (via Dropbox, googledrive, or…) can also be helpful in many cases, although it is of course difficult for anyone, asking a question, to know what is needed; sometimes a description of the problem is enough, sometimes it is almost impossible to solve without access to the .blend….
            #75140
              Hello Riley. Same as Martin, I can’t tell much of the problem with that screenshot. I’m thinking maybe it’s those faces I see slightly bent right where the origin point is? But anyways yeah, that tends to happen when you have some vertices were misaligned. Your project seems to be going great thought, you’re making good progress. Keep it up.
            • The topic ‘Unexpected Bevel Geometry on Side Panel’ is closed to new replies.
