Unable to figure out the rotation of lid (wood & metal) back to exact closed position part of vid-approx 6:32 of blocking metal pieces chap.
Forum Archive Unable to figure out the rotation of lid (wood & metal) back to exact closed position part of vid-approx 6:32 of blocking metal pieces chap.
  • #12647
    curtisdd1
      Hi, I applied scale to the wood section of the lid ( via another questions answer )and trying to figure out what we are trying to do exactly to get the whole lid to rotate to an exact closed position again.
      #60003
        Since I used the cursor as the point of rotation instead of the object’s origin, it makes for a weird transformation; hard to explain in textually. If you post a download link to your .blend file I’ll be happy to record a GIF of the process. The best way to do this is by uploading your file to Dropbox, Google Drive, Mega, or equivalent file hosting service then copy + pasting the share link here.
        #60004
        curtisdd1
            Thanks for posting your file! As I’d hoped, you’ve left it in the perfect state to be fixed:
            Essentially you just want to negate the X rotational value:
            1. With both top pieces selected (rim as active), hover over the X rotation value and hit CTRL + C to copy.
            2. Make sure you’re using the 3D cursor as the pivot.
            3. Hit R to begin rotation and then CTRL + V to paste the value into the rotation operator. Note that you can press the “-” key to negate the value if it rotates in the opposite direction as desired.
            4. Hit ENTER and you can see that the operator has inherited the pasted value.
            #60006
            curtisdd1
              Got it.  Its interesting that you have to re-rotate the metal & wood part of the lid and negate the previous rotation with a negative rather than just zero the x rotational value.  Zeroing out just causes the active object to be rotated about its origin on the x axis.     This is much simpler than it seemed.  Thanks!
              #60007
                If this were rigged it would definitely be setup where zero-ing out the value would return it to perfectly closed. But in this case it was merely a quick-and-dirty modeling demonstration that utilized the 3D cursor instead of the object’s origin.
                Check out the rigging course after this! Sounds like your head is already aimed that direction 🙂
              • The topic ‘Unable to figure out the rotation of lid (wood & metal) back to exact closed position part of vid-approx 6:32 of blocking metal pieces chap.’ is closed to new replies.
