Turn off “fast navigate” in the options on the upper right corner if you are using the sculpt layout and can’t see the mesh details when orbiting around the object
Forum Archive›Turn off “fast navigate” in the options on the upper right corner if you are using the sculpt layout and can’t see the mesh details when orbiting around the object
I actually think it is default in 2.9. If you go to File > Defaults > Load Factory settings you should see that that option is still enabled in sculpt mode. I agree it’s not what I want on by default.
Author
The topic ‘Turn off “fast navigate” in the options on the upper right corner if you are using the sculpt layout and can’t see the mesh details when orbiting around the object’ is closed to new replies.
