Trouble with Vonn bots in Blender 3.4.1
Forum Archive Trouble with Vonn bots in Blender 3.4.1
  • #16102
    Walter Haas
      I loaded the VonnBots_3.0.blend file and got Stomp’s rig and geo OK, ran the rig_ui script and got the UI in pose mode, but I can’t find Simple_Blocks and when I select an object in the layout window and try to switch to Edit mode I get an error message.  I’m sure I just did something stupid, but what is it?
      #78164
        Hi Walter @Walt Haas ,
        The Simple_Blocks are now called Simple_Pillars and they are in the Env Folder. When you have Linked in Stomp, you need to make a Library Override of the rig:
        Then you can go into Pose Mode.
        Edit Mode is not available (I believe) with Linked models, unless you make them Local (like Appending, instead of Linking), but you don’t need Edit Mode for this.
      • The topic ‘Trouble with Vonn bots in Blender 3.4.1’ is closed to new replies.
