Tried beveling the corners, but they won’t bevel
Forum Archive Tried beveling the corners, but they won’t bevel
  • #18593
    Jann Raqui Tome
      #88804
        Most likely you have clamp overlap turned on. Clamp overlap works on the model as a whole. It just prevents things from blowing up. So if it blows up, just try dialing the bevel down.
        #88805
          The other ‘classic’ is so-called ‘Double Vertices’.
          Select all (in Edit Mode) by pressing A, followed by M > Merge > By Distance.
          #88806
          Adrian Bellworthy
            Can we see a screenshot of your selection while trying to Bevel the corners?
            Do you have the edge selected or the vertex?
            As mentioned it could be double vertices. A little more info is required to be sure of the problem and provide the correct answer.
            #88807
            Adrian Burley
              Clamp Overlap fixed it for me, thanks!
            • The topic ‘Tried beveling the corners, but they won’t bevel’ is closed to new replies.
