Topology-Sectioning Out and Making the Ears
Forum Archive Topology-Sectioning Out and Making the Ears
  • #8848
    Jahim Clarence
      Hey there,I’m  trying to model the ears with clean topology and im struggling with how to section out the body in general.I have gone through the whole course and I’ve been going over Quad Junctions and the 5 main loops.Nonetheless,I still find myself coming to a roadblock.Was wondering if I could get some further insight maybe?
      #29496
      Jonathan Lampel
        Hey @jahaura , can I get a screenshot of where you’re at so far? It’s hard to tell what kind of advice would be helpful here without seeing where exactly the roadblock is.
        #29497
        Jahim Clarence
          Hey @jlampel,I actually fixed that problem and i feel good about it!I am having difficulty with getting dangerously close to the poly count limit though.Can I send a screenshot of that instead for advice on my topology?
          #29498
          Jonathan Lampel
            Sure thing!
            #29499
            Jahim Clarence
              Poly Count is currently 6,204
              #29500
              Jonathan Lampel
                Hey, looking good! The poly count is only high because of the subdiv, the limit and submission is the unsubdivided model which is only at 387.
                Be careful around the side of the neck, that’s looking a little pinched in the top screenshot. Maybe it’s the angle. A possible solution is to try to even that area out using a junction to turn the loop up and around the neck.
                Keep up the good work!
              • The topic ‘Topology-Sectioning Out and Making the Ears’ is closed to new replies.
