Topology problem weird lines on object.
Forum Archive Topology problem weird lines on object.
Viewing 2 posts - 16 through 17 (of 17 total)
  • #72713
      Right, you have a hidden Vertex here:
      in Edit Mode ALT+H to show it and the Delete it (this is also in Cube.009, but connected by an Edge and that gives one of those strange lines in Object Mode, because parts of a Mesh, that are Hidden in Edit Mode, are visible in Object Mode!).
      Furthermore you have an extra Edge that shouldn’t be there:
      A bit tricky to select when not moving that corner, but try it in Wireframe. When that Edge is removed, all looks fine:
      #72714
      pyrefiend
        Thanks alot! It’s fixed now.
      • The topic ‘Topology problem weird lines on object.’ is closed to new replies.
