To make the cut off corners on the first one, is there a more efficient way ? I used the knife tool and cut a triangle and then disolved the faces individually.
Forum Archive To make the cut off corners on the first one, is there a more efficient way ? I used the knife tool and cut a triangle and then disolved the faces individually.
  • #7393
    Terence Arseneault
      Never mind i read through some of the other previous questions and found my answer
      #27000
      Ingrid Frank
        Select the vertices of the corners, press CTRL +B to access the Bevel tool. Press V for Vertex only mode.
        #27001
        kossuth
          I used the knife tool as well, thanks for the answer. I think I need to experiment more with the bevel and inset tools, it didn’t even occur to me to use the bevel tool with vertices.
        • The topic ‘To make the cut off corners on the first one, is there a more efficient way ? I used the knife tool and cut a triangle and then disolved the faces individually.’ is closed to new replies.
