Tip to solve unwanted geometry changes on changing shape keys. (Mainly at the corner of eyes and mouth)
Forum Archive Tip to solve unwanted geometry changes on changing shape keys. (Mainly at the corner of eyes and mouth)
  • #17070
    Arshdeep Singh
      If you are having spikes, I recommend smoothing them with a smooth brush by clicking at the top of the spike continually first and then applying this method to prevent them from generating again on changing shape keys. (Please check if they generate again on changing shape keys before applying the method and if not, you can still watch the video to learn about a new brush)
      The Problem Video
      https://drive.google.com/file/d/1heHcEr5EcAlw1Of17QnLz87-BDyri6MQ/view?usp=sharing
      The Solution
      https://drive.google.com/file/d/155jmCP1bq4caK_PlJT5r2b6Btf3zm6oc/view
      #82153
        That’s great Arshdeep 👍🏻. Thanks a lot!
        I never knew how to use that Multires Displacement Eraser Brush.
        Bookmarked this post and Downloaded the video, so I can easily find it when someone else asks.
        #82154
        Abdullah Alshammari
          I wish I had found your tip here before I wasted a couple of hours trying to fix this the wrong way.
          Thanks a lot!
        • The topic ‘Tip to solve unwanted geometry changes on changing shape keys. (Mainly at the corner of eyes and mouth)’ is closed to new replies.
