Time node?
Forum Archive Time node?
  • #16005
    Toby Capozzoli
      Hi. Where is the time (scene time) node in 3.4? I had learned it works well to create flicker for fire
      #77830
      Craig Wieland
        Are you talking about Geometry nodes?
        #77831
          Hi Toby @Cap3d ,
          In the Shader Editor, you can (for instance) use an Input > Value Node and set the Value to: #frame. If you wanna go fancy and impress your friends, you can name the Node (Label)  Time:
          and in Geometry Nodes, you can simply search for time, to find the Node.
          #77832
            I’d say go with the fancy option Toby, impress some friends.
          • The topic ‘Time node?’ is closed to new replies.
