This is a nice technique for a problem I’ve being having, where I’d like to use Newtonian physics on closed loop where particles go round and round in the same direction. I solved this to a degree by using positive z on the curve force to get the particles moving round in the same direction, however doing this leaves a considerable amount of particles on the emitter?
thanks Jonathan, that seems to have sorted it, it’s just the initial velocity on the x that make it work, without that, the particles go in both directions.
Author
The topic ‘This is a nice technique for a problem I've being having, where I'd like to use Newtonian physics on closed loop where par…’ is closed to new replies.
