this fill thing aint working
Forum Archive this fill thing aint working
Viewing 14 posts - 1 through 14 (of 14 total)
  • #16665
    Skyler Blaise
      around the 1:45 mark he talks about selecting all the vertices of the d pad and hitting fill will make one solid face. that doesn’t work for me. the 5 individual squares remain.
      at the 3:04 mark he connects the vertices between the edge of the console and the d-pad using the (left mouse + shift left mouse) click combo and then strings those connections all around the bottom side of the console. that also doesn’t work for me. can’t make a single string connection even though i follow all his click/button combo commands exactly.
      at the 3:37 mark he’s using the ctrl button to connect vertices all around the edge of the console, and he also has a PICK SHORTEST PATH window. none of that works or is happening for me
      #80419
        Hi Skyler @skyblaze ,
        at this point, I think Omar gave  the best advice in answer to your other question; at least watch (and practice):
        https://cgcookie.com/courses/blender-3-basics-intro-to-blender
        As for the D-pad, try Select All Vertices, M > Merge > By Distance, followed by SHIFT+N. This may or may not help. Or better: make it again (easy way: Add a Plane in Edit Mode, Subdivide (2 cuts) and Delete the 4 corner Vertices).
        If you can’t make a ‘string’ of connected Vertice, you might have Double Vertices; again: M > Merge > By Distance.
        If you can’t see the popup Window, check the Adjust Last Operation checkbox:
        #80420
          Hello Skyler. Well, Blender is tricky and it’s impossible for us to guide you through every click you have to make, text based conversation for troubleshooting is challenging enough. In the beginning things wont work the way you expect and you see the people on the video doing it like it’s nothing, but that’s because they have years and years of experience. So just stick to it, try it over and over again and little by little you’ll start to get the hang of it.
          The way I watch tutorials is that I watch it first as if it was a movie, just paying attention and not doing anything with the mouse. Then I watch it a second time and this times I’m hands on with the mouse and Blender open, trying to do what I see on the screen and following the explanations. And if I get stuck, I go back to the beginning and try it again, only this time I for sure am faster and get pass where I got stuck. But again, the key word is grit, trying and persevering.
          #80421
          Jonathan Lampel
            Also, if you want to share your file when you get stuck, we can look at it and diagnose the issue much faster than guessing from the description. I hope Martin’s suggestion of merging vertices and recalculating normals worked for you! That would have been my suggestion as well.
            #80422
            Skyler Blaise
              still stuck. unable to attach the .blend file. no attachment options on here. sent it to support yesterday. maybe they still have it. idk
              #80423
                You can upload your .blend file to Dropbox, Googledrive, or so and post a link here.
                #80424
                Skyler Blaise
                  still stuck. wasted way too much time on this one step.
                  at the 3:37 mark he’s using the ctrl button + left mouse click to connect vertices all around the edge of the console, and he also has a PICK SHORTEST PATH window. none of that works or is happening for me. unable to make the faces as a result or continue.
                  why?
                  #80425
                    Hey Skyler,
                    Like mentioned before> please upload your .blend file.
                    #80426
                    Adrian Bellworthy
                      It sounds to me like you may already have faces where you are trying to fill.
                      If you share a screenshot, we may be able to tell you exactly what is wrong.
                      The .blend file would be even better.
                      #80427
                      Adrian Bellworthy
                        Also use CTRL + Left Click to select shortest path.
                        SHIFT + Left Click will add to the currently selected.
                        In your original question you mentioned SHIFT.
                        #80428
                          Again, you can also consider putting Press Start on pause and jump into a simpler course. You might run the risk of getting discouraged. Press Start is beginner friendly but it does have some tricky stuff underneath. I suggest you build yourself up by watching other fundamental courses first. If not, well then press on, we are here to help if we can.
                          #80429
                          Skyler Blaise
                              Hey Skyler @skyblaze ,
                              Here’s your problem:
                              Blender needs an Active Vertex to know where to start the Shortest Path from.
                              #80431
                              Brian Ireland
                                Unless I’m mistaken, ‘F’ hotkey works for filling in mesh objects. Did you accidentally create a bezier circle?
                                Note: my fill “wasn’t working” either, that’s how I figured this out, so you’re not alone!
                              • The topic ‘this fill thing aint working’ is closed to new replies.
