There looks to be a discrepancy with blender 5.1 for extrude.
Forum Archive There looks to be a discrepancy with blender 5.1 for extrude.
  • #21607
    Josh Chernoff
      At 10:40 when making the extrude I get a different result than the training.
      You can see at the corners when pulling in I don’t get the clipping I would expect but instead there are these triangles created. Also if I hold alt while dragging in the extrude I don’t have some of the same alignment issues you later address.
      I assume my best option is to try to merge these verts by hand?
      #100433
        Hi Josh @FullStacking ,
        That has nothing to do with a difference between 4.2 and 5.1, but with you having made a (or more) mistake(s) along the way.
        Now I don’t know exacvtly what you did, but if you, go back to just before the Extrude and then Select everything (with A) and M > Merge > By Distance.
        Then it should work fine.
        If you can’t go back, you’ll just have to fix them by hand, like you say.
        #100434
        Dwayne Savage
          My first guess is that you are in edge select mode instead of face select. Also possibly double vertices?
          #100435
          Josh Chernoff
            I tried to reproduce and indeed it must have been something I did along the way, not seeing the same effect the second time around.
            #100436
              It’s hard to reproduce, but it might be an unintentional ALT+V (Rip and Fill) on the corner Edges, before Extruding.
              #100437
              Josh Chernoff
                TIL: There is a visual undo history in the edit menu. This is going in my quick favs.
                #100438
                  Oh cool! I didn’t know that.
                • The topic ‘There looks to be a discrepancy with blender 5.1 for extrude.’ is closed to new replies.
