The tile texture for the background is missing, so in the rendered view it appears purplish/pink, just as Kent said would happen to an object if it had an image texture node without a texture applied. Sure enough in the node editor there’s an image texture node feeding into a mix -> diffuse -> material output. I tried adding the checkered texture but it seems to be missing from the list.
