The sheep icon appears to have custom dimensions which give the illusion of inconsistent spacing. Any recommendations how …
Forum Archive The sheep icon appears to have custom dimensions which give the illusion of inconsistent spacing. Any recommendations how …
  • #6053
    chromemonkey
      The sheep icon appears to have custom dimensions which give the illusion of inconsistent spacing. Any recommendations how to give it a custom offset, or is this something that would require making alterations to the other three character icons so that all four icons have consistent frame widths?
      #24844
      Jonathan Gonzalez
        You could slice up the sprite to have the same dimensions as the others. Click the icon sprite sheet then use the sprite editor to adjust the size of the selection boxes by adjusting the width and height values.
        Ideally the icons would be created using the same dimensions initially, but they were all created separately. A few of the icons were created together and some like the sheep were created afterward so the sheep looks bigger in comparison to the others.
      • The topic ‘The sheep icon appears to have custom dimensions which give the illusion of inconsistent spacing. Any recommendations how …’ is closed to new replies.
