The render settings are not applicable to Blender 4.0+
Forum Archive The render settings are not applicable to Blender 4.0+
  • #18318
    Ben Leffler
      The render settings mentioned in this video are not available or have been moved around within 4.0+.  Is there another tutorial that can assist with getting the eyes setup?
      #87482
        Hi Ben,
        What do you mean by Render Settings? Quickly scrubbing through this Lesson, I think Kent just changes the Output to 300% and that hasn’t changed. In fact, I don’t think the Render Settings have changed that much since 2.93.
        Are you perhaps talking about the Subsurface Scattering in the Principled Shader?
        If so, set the Weight of the Subsurface Scattering to 1 and play with the value of the Scale. You might also benefit from changing the method to Random Walk (Skin).
        If you mean something else, please be more precise and also give a timestamp as to where in the video you get into problems.
        #87483
        Adrian Bellworthy
          My thought’s exactly, the Render settings???
          The only thing in the render settings that is different that Kent uses in this video, is the viewport denoise, and all he really does is turn it on.
          The only other change I see in this video is the Principled BSDF, and most of that is just the layout.
          #87484
            And also remember, Blender changes too much too fast, there isn’t a single tutorial that survives long enough to follow exactly, so what we all do is we use the Blender version that is used on the video so we can follow along without getting distracted with UI changes. The point is to get the knowledge, not what buttons to press. So you can follow the course with the Blender version that is being used to avoid such small inconveniences,
            #87485
            kai fuhrmann
              That’s true. If you’re referring to the transparency effect:
              1. You have to check the “Raytacing” in the render options of Eevvee.
              2. In the shader editor of the sclera, set the Thickness value (with a value node) to 0.
              3. In the Materials tab of the sclera material under Settings -> Surface -> Render Method -> Check “Raytraced Transmission”.
              #87486
                Yes Kai @KaiFu , that is true,
                But you are referring to the new EEVEE in 4.3+ and that wasn’t available yet when the question was asked.
                Also, this Lesson uses Cycles 😉
              • The topic ‘The render settings are not applicable to Blender 4.0+’ is closed to new replies.
