The textures are packed into the .blend file, so you can find them in the UV image editor or by searching within an image texture node.
As for AO, I typically mix my material with a black diffuse shader and use the AO map as the mix factor. Hope that helps!
Apologies for not seeing this until now, thankfully we have a new system in place to make sure questions don’t go unanswered in the future.
