The hole in the statue that I cannot close
Forum Archive The hole in the statue that I cannot close
  • #18235
    Ahmet Yavuz
      While working on the sculpture, a small hole occurred. As seen in the video, I tried everything I knew, but it does not close. It is not visually disturbing, but will this hinder my work in the future? (Will it cause errors in the texture – lighting etc. phase)
      #87118
      Ahmet Yavuz
        and strangely there is no hole on the other side of your head
        #87119
        coyo
          Heya! It doesn’t really look like a hole to me. It looks like a mask…though it doesn’t seem to be actually masking anything. Try Alt-M to clear masks to see if it goes away.
          #87120
          Ahmet Yavuz
            You’re amazing, yes it was a mask. It’s fixed, thank you very much.
            #87121
            coyo
              Yay! I’m glad that worked! If you no longer want all the geometry you added while brushing over it with Dyntopo enabled you could give it a couple swipes with the Simplify brush. That one spot of dense geometry might behave strangely as you proceed.
              #87122
              Ahmet Yavuz
                Oh yes I use this brush from time to time. Thank you again for the reminder.
              • The topic ‘The hole in the statue that I cannot close’ is closed to new replies.
