The faces around the outer circle are light gray, the faces that I made by extruding vertices around the bites are a much darker gray. Why two colors?
Forum Archive The faces around the outer circle are light gray, the faces that I made by extruding vertices around the bites are a much darker gray. Why two colors?
  • #7044
    Richard Hardy
      Jonathan Lampel
        Hey Richard, faces in 3D have an outside and an inside, so the two colors are telling you that they’re pointing in opposite directions (the normals are flipped). Select everything and go to Mesh -> Normals -> Recalculate Outside to fix them.
        #26426
        David Frazier
          Light gray = normal is facing outward. Dark gray = normal is flipped.
        • The topic ‘The faces around the outer circle are light gray, the faces that I made by extruding vertices around the bites are a much darker gray. Why two colors?’ is closed to new replies.
