The collision physics are not rendering. The smoke is just going through the floor but when I play it back in the viewport render it looks correct. What am I doing wrong?
Forum Archive The collision physics are not rendering. The smoke is just going through the floor but when I play it back in the viewport render it looks correct. What am I doing wrong?
  • #12285
    chisburger
      #58553
      Ingmar Franz
        Did you maybe check “High Resolution” in the  “Smoke” panel of the “Physics” tab of your smoke domain (see bottom right corner in the image below)?
        This “High Resolution” effect is a kind of displacement done after the physics calculations have been finished and therefore doesn’t respect any collision objects
        #58554
        chisburger
          Oh  I didn’t use any smoke physics in the render. The smoke is actually just particles. I figured it out though, I had to bake it first lol the tutorial didn’t mention it. Thanks for your reply though!
          #58555
          Ingmar Franz
            Yes, indeed, tweaking the settings for the particles can lead to outdated data in the particles cache. Refreshing the cache by changing for example the cache step number and then resetting that  number to the old vaulue (mostly step size “1”) should solve this problem, too. Baking the particle simulation nevertheless should always be done before the final rendering it in order to have all physics simulations in your scene up to date.
          • The topic ‘The collision physics are not rendering. The smoke is just going through the floor but when I play it back in the viewport render it looks correct. What am I doing wrong?’ is closed to new replies.
