The chest control won’t move freely after disconnecting the bone parent
Forum Archive The chest control won’t move freely after disconnecting the bone parent
  • #19312
    Andy Shek
      14:11, after disconnecting the bone parent of the chest bones, the chest control bone should move freely. But I can’t move it at all. What might be the reason?
      #91621
      sheila5
        I’m almost at that part, going to continue tomorrow and see if I have the same issue
        #91622
        Wayne Dixon
          Hi Andy,
          I can’t tell for sure but if it has a disconnected parent, and you can’t move it, it’s probably a constraint that is holding it in place.
          If you’re still stuck, upload your work as the exercise, or post a video of your issue.
          #91623
          Andy Shek
            Hi Wayne,
            Thank you for replying again.  I’ve submitted my work for your review.
            #91624
            sheila5
              Ok I think you did the same thing as I and removed the connection on the DEF-Chest instead of the Chest (control)  perhaps?
              #91625
              Wayne Dixon
                I added the detailed explanation on how to fix this issue on the submission comments.
                However, to summarise the cause of the issue here.
                There was a copy-transform constraint that was not allowing the Chest control to move (it was being pinned to the DEF-Chest)
                Clearing the constraint and parenting the Chest control to the Torso control will rectify the issue.
                #91626
                Andy Shek
                  Hi Wayne,
                  Thanks you reviewing.  Now it looks like fine:
                  https://youtu.be/vG_9LX4rGS4
                  But it raises another question.  Why did we have to make the Copy Transform constraint in the first place if the constraint has to be cleared at the end?
                  #91627
                  Wayne Dixon
                    Hey Andy, I’d have to watch it through again to see exactly where the error was made.
                    But my guess is you selected the bones in the wrong order.
                    I can assure you that I did not add a Copy Transforms to the Control bone.
                    #91628
                    Andy Shek
                      Hi Wayne,
                      I might have misunderstood in the constraint process.
                    • The topic ‘The chest control won’t move freely after disconnecting the bone parent’ is closed to new replies.
