The bevel around the device is messing up around the Battery Hatch
Forum Archive The bevel around the device is messing up around the Battery Hatch
  • #14961
    Kendrick Granville
      The only point on device its doing this. I tried to merge by distance and removing the edge within the battery hatch wall to no avail. Not quite sure where to attack this problem at, i don’t any differences in wireframe + X-ray mode.
      Edit* i think it may be my face orientation is off. I will shift+N and see if the fixes it.
      Edit 2* That fixed it! 😀 i would delete this post but ill leave it up just in case someone in the future has my problem
      #73797
      Kendrick Granville
        #73798
        Adrian Bellworthy
          Flipped normals, duplicate verts, these are the most common reasons things don’t work they way you expect.
          Glad to see you solved the problem.
        • The topic ‘The bevel around the device is messing up around the Battery Hatch’ is closed to new replies.
